Need help
I have a steering angle sensor issue but can’t seem to find it, any help would be greatly appreciated thank you!!!!
The steering angle senor is also a part of the ESC system...it is underneath the steering wheel as in the steering wheel will have to be removed in order to access it for repair.
J
Dickinson, ND, USA
Where can I find the part I have no clue what it looks like
Call up FOMOCO and tell them you need a steering angle sensor* the steering wheel needs to be removed to access it* Its pretty blatant once the steering wheel has been drawn/pulled off.
SteveS
Osage Beach, MO, USA
It should be right behind the clock spring. It may not need to be replaced; typically it has to be reset using a computer (and maybe Forscan?)
