Gretings.
As the title says, I’m a bit confused regarding the controllers and actuators. I know how they work, but I’m trying to find when is the right time to add better ones. And i apologize for the basic quesrions and if i’m confusing you also very soon.
The turbo in case is the X47r.
So, according to pumaspeed on some other thread, the turbo works wonders at 23-24 psi. An 11 psi actuator is very good for this because when the turbo makes max boost, the valve is opened completely(something like that).
When the wastegate is max open, the turbo still makes 23 psi, right? So in reality the turbo makes actual boost+wastegate leak?
Is the wastegate tuned/made in such manner so that it Leaks “X” psi so the turbo can get to 23psi?
If I would add a bigger wastegate and made it open wide, i will get lower boost, correct?
Is there a reason to add a boost controller(besides maybe fine tuning) to a turbo that’s been made specifically to give 23 psi?(assuming everything I said before is correct)
If I go bigger turbo, lets say 2867R and an external wastegate. The gate has its own actuator if I remember corectly, lets assume 11 psi also. But the wastegate is bigger so if it opens max, the turbo will make less boost, right? Would a boost controller be more important then?
I hope I made some sense.
Thanks for the help.
Regards.
Ps: is anybody running a boost controller on any turbo?
Regards.
