New transmission under warranty.
Dropped what came from the factory at 2K, then poured in the full 2L of Ravenol. Dumped the factory fluid into the 2 Ravenol empties. Guess mine was sent out with the old spec 1.5L. Luckily no strange mechanical sounds before the change or thus far.
Informacion
Thread Starter #22
Mine is whining in all gears under load, gets louder as speed increases, nothing if i get off the gas or clutch in.
This post gives me hope about getting this warrantied
Definitely do a road test with a tech, if they have another Fiesta on lot make them drive that as well to really show the difference. You shouldn't have an issues I'd imagine..
Informacion
Thread Starter #23
On another note, 57 degrees this morning on my drive to work, seems to still have that whirring noise that it had before the transmission switch, just not as loud. When I drove the other Fiesta they had on lot I did notice the same sound just not as noticeable or as linear. Also could've swore I heard a whine on the drive, more noticeable at higher speeds 5th and 6th gears. I will do a fluid change in the next week for sure, if that doesn't do the trick then I'm at a loss and will drive it till the wheels fall off. :coffee:
