Last weekend after a lot of research for a daily driver, one article after the other it was evident that the fiesta ST was just what i was looking for. After months of stalking several ST's, I ended up picked up this wrecked 2016 Fiesta ST. It was a 4 hour drive to the repairable car lot that this car was listed at, once I got a better look at the car I purchased it.
Pulling Home
In the shop
Once I got it home, I immediately Pulled it apart making a parts list as i went. Initially the front end seemed worse then advertised but once I got further into it, I feel like I lucked out and was able to straighten both the radiator and A/C condenser bent back without any leaks.
In the wreck several parts were broken including the intercooler, oil pan, RH steering arm, front bumper and various brackets.
Cracked intercooler
Bent steering arm
The oil pan was cracked pretty bad, so i had it welded up by a friend last week.
Outside Crack
Inside of Pan
Outside after welded
Inside after welded
This weekend I was able to get the oil pan back on and started to install some of the other parts like the radiator support only to realize i was missing some rubber grommets so some more parts added to the needed list
After mocking parts up I Noticed that this tube had both a broken mounting bracket and what i assume is the oxygen sensor was broken also. More to the list
Please see the link if you have parts you would like to sell, I will update as i find more broken parts...
http://www.fiestastforum.com/forum/threads/14103-WTB-OEM-Front-End-parts
More on the Car for those interested it's a 2016 it has 16,000 miles with Recaro seats
Long term goals for the car is a great daily driver, I see an intake, intercooler, probably a resonator delete in the future, main focus is to get the car up and running as soon as possible, the doors and rear quarter panel will likely remain damaged for awhile. both door windows roll up and down . I can't seem to source just the door shell right. so I will be patient and keep locally at salvage yards for those items. I have ordered some more parts to get me to the next step in at least getting the front end back together minus the body parts. right now i'm focusing on the mechanical parts. Please if you have any suggestions on what should just be upgraded rather the replaced with OEM parts please let me know.
Pulling Home
In the shop
Cracked intercooler
Bent steering arm
Outside Crack
Inside of Pan
Inside after welded
