On my second trip after doing some work to the FiST, something has gone funky. I've ran a KOEO and OFF and the only code I get consistently is p0505. Would that point to the throttle body?
I've checked for vacuum leaks, tested all the check valves and the purge valve, all working like they should and not blocked.
Swapped out the boost sensor and map sensor.
Car will start up just fine and run fine for a couple seconds then go super rough, sometimes dying.
Runs a little better if I pull the EVAP line off the front of the throttle body but not totally fine.
Poor car has been sitting at the end of the driveway for weeks now, riding the bike kinda sucks in this heatđ„
