Just installed an S280 with 14lb wastegate and Turbosmart BOV. Also installed Stratified 4-port. Getting custom tuned from Dizzy.
After the 3rd tune with just stock fuel, Jason said all looked good. He sent a revised tune and the fuel maps for the 4-port.
After a couple quirks, the tune was running great on Friday. Took it to the gym this morning, and it was awesome … actually touched 29 lbs of boost. It felt FAST.
I come out of the gym and now the car is like it’s NA. Won’t go past 5 lbs of boost. I have checked all hoses and can find nothing obvious that would cause a boost leak. No codes and no misses. I even unplugged the Aux fuel and went back to the prior tune …. no difference.
This is normally a track dedicated car, so the steering wheel is aftermarket. So, I couldn’t have hit any cruise buttons wrong to put it in some sort of valet mode. I guess it’s possible that the snipped lines behind the wheel touched or were grounded, but that seems unlikely.
I did try unplugging the battery and reloading multiple tunes to no avail. The Accessport says I’m in “Map Slot 1,” but I don’t know if it would say that with Dizzy custom tunes or not? When I check which ECU is loaded, it says it’s the Dizzy tune.
I don’t know what else to try here.
