P219A Code
Spring, TX
Car has intermittently thrown a P219A: Aif-Fuel Ratio Imbalance
Any quick checks fixes common this one to look into?
No performance effect that I can tell. Only possible symptom is it's averaging around 27mpg, but I've been having fun with it too, so that likely contributes to the lower MPG.
JAMADOR
Spring, TX
Thread Starter #2
Seems to have resolved itself? Haven't scanned codes, but the CEL is off now after about 100 miles on a fresh tank of gas [Shell 87]
Last tank was Costco 87
Grsemky
Arizona
Try using premium gas.... I personally only put 91 in it, I live in AZ and get that California 91... My MPG averages 30.1 combined
JAMADOR
Spring, TX
So, a maybe symptom.
CEL returns on a full tank & seems to go away when it gets down to around 3/4 full.
Will verify over the next tank or two to see if that's consistent.
Sam4
West Chester, PA, USA
Is it a corn-related thing? Are you using high alcohol/low octane fuel? The 3/4's makes me think of the evap system and hose - I literally only put in 10 gallons anymore.
JAMADOR
Spring, TX
Not sure on the ethanol part.
Last 2 tanks have been Shell 87 from the same station. Would have to look, but think the 2 before that were Costco 87.
If the next tank does the same CEL from full to 3/4, I'll try a tank or 2 of 93 and see if that has any different effect.
Mesa, Arizona, USA
Change o2 sensors? I had a p219a issue and replaced upstream & downstream and it went away. It was just an underlying code and never actually threw the light, but just a suggestion
JAMADOR
Spring, TX
O2 sensor(s) or evap were my leading 2 guesses.
Evap more because it seems to be consistent with a full fuel fill.
JAMADOR
Spring, TX
Seems this code is persisting now. CEL came back on at about 3/4 of the last tank. Filled up this morning at 1/8 & still have the light on.
Think I may throw a new set of O2 sensors at it, seeing Bosch, Denso & Motorcraft, with the MC being the priciest of the 3, but being the 'Ford' branded would be my first thought to use. Any reason to not go with the Bosch or Denso?
Also, if that doesn't resolve anything. Where is the Vapor Canister located? The parts diagram doesn't really give a lot of location indication.
Or, are there any parts to inspect prior to throwing some $ at it? I had a persistent lean condition on my Mini that the FiST replaced. Turned out to be a tear in the intake boot, between the MAF & TB. Was able to patch it with some high-temp liquid gasket & it held fine up until trading it in.
Mesa, Arizona, USA
i'd just opt for Denso, it worked out on my car with the p219a that I had, i replaced upstream & downstream and it went away, never came back. i think denso was cheaper too
JAMADOR
Spring, TX
Thread Starter #14
The Denso sensors are about 1/3 [DS] & 2/3 [US] the price of the MC options, at RockAuto
JAMADOR
Spring, TX
Thread Starter #17
New plugs & both O2 sensors [Denso] ordered. Hopefully that does it. Needed plugs anyway. 4 plugs & both sensors from RockAuto was less than just the sensors [Motorcraft] from a few Ford parts warehouses.
JAMADOR
Spring, TX
Thread Starter #18
And, of course, parts are due to arrive today & CEL turns itself off. :ROFLMAO:
