Car is still at Circuit Demon, guess it was next up on the dyno yesterday afternoon sometime, so I'm hoping to hear back/pick it up today.
Had a few observations I wanted to note before I forgot now that I've had a fair bit of miles with having actual oil temperature and pressure visible.
At idle and when warming up, the oil temperature reported on the AP varies from 5-15 degrees warmer than the reading I get on the gauge (sensor is in the sandwich plate, and there is always a little oil flow through the cooler to avoid thermal shock), but when you have been cruising at operating temperature (coolant) for an extended period of time the inferred oil temperature must be assuming the oil temperature and coolant temperature align and overlay (which makes sense because with the factory cooler, they are literally interacting). So, the 5-15 degree delta at idle and startup elevates to ~40 degrees after cruising for a while, AP says ~200 degrees while the gauge says ~160 degrees. I'll have more data on this after hitting the track and getting some real heat in the oil.
Secondly, the first batch of oil was Motul break in oil 10W-40, the next 3 changes were conventional 10W-40, and the newest batch is Amsoil extended life 10W-40 (which I'll run moving forward per SP63s specification). The interesting thing is, now with the Amsoil in, the oil pressure from start to ~140 degrees is 5-8 psi higher than it was with the break in oil and conventional 10W-40 (idling and cruising). Once its warm, idle and cruising pressure are basically the same as with the others, seems the different formulation acts a little different at lower temperatures.
