Soo.. just finished installing my Whoosh radiator to help combat the overheating problems I've been having when the temps outside get over 95. My '14 Fist would quickly overheat when it was that hot out and I ran the AC for more than ~15 min. Now that I've buttoned the car up and took it on a hill climb to test drive, I noticed the AC clutch will not engage to turn the pump on. I can short circuit the wire to activate the clutch by removing the relay (R6) and the car blows ice cold. I've swapped relays to test if that one is faulty as well as triggered it with the battery and checked for continuity. If I put a multimeter in the control pin slots I'm reading a steady 10.2V which should be enough to trigger the relay since I even tested that I can trigger it with a 9V battery.
The weird thing is that the relay control pin slots are reading that 10.2V even when the A/C button is turned off..
The AC blew cold last night before I did the swap. Also, using an AC gauge on the low pressure side while the AC compressor is running with the jumper wire I'm reading an acceptable 40-45ish psi.
And yes I understand the irony of doing a radiator swap so I can run my ac when it's really hot out, and busting my AC completely in the process
. Any assistance or double checking that your car shows the same is much welcomed.
