Rear Caliper Disassembly Question
Detroit
Has anyone disassembled their rear calipers before? I'm trying to get this unpainted bracket off but I'm not sure it's even meant to come off. It turns and springs back fine but I want to take it off if possible, because I'm getting the caliper powdercoated and it would save a lot of tricky masking.
Montreal
Have you removed the piston yet? You have to spin it out. There may be a bolt inside the piston bore to untie that pivoting part.
2nerkid
Detroit
Yes, got the piston out. The inside of the bore looks like this and I can't figure out any way to get that threaded rod out. It rotates along with the bracket. I tried pushing the rod in a bit with a C clamp but it wouldn't budge, unless I'm not trying hard enough. Didn't want to try too hard though in case I'm right and it's not meant to slide out like that.
2nerkid
Detroit
There's a nut on the outside, on top of the bracket, but I've already removed that and it didn't free anything up. However, I did take a closer look at the inner bore and saw that there is a retaining ring inside underneath the... whatever that inner piston looking thing is called. If you look at the one o'clock position you can make out one eye of the retaining ring, there's another at 11 o'clock (it was hard to get a decent photo of both together). I'll try using a snap ring plier to fish it out.
2nerkid
Detroit
Yes, I've removed both of those. The Torx bolt on the bottom frees up the bottom bracket but it's trapped by the top bracket. The top bracket doesn't come off even with that nut removed... it does seem like it's supposed to though, my calipers may just be that seized. I had hit one of them with Liquid Wrench and it still didn't budge but I'll try Kroil on both.
2nerkid
Detroit
Soaked in Kroil for four or five hours, tried pulling the bracket, no dice. Have you taken these brackets off before? I see the outside threaded rod has a spline so it stands to reason the bracket should come off of it, you reckon I should rent a puller tool from Autozone and try that?
2nerkid
Detroit
No, I'm just getting them powdercoated. These are actually a spare set that I bought from someone else's car, mine are the nonpainted version and still on my car. For all I know this set had the stuck ebrake problem and that might be what I'm encountering now.
2nerkid
Detroit
Thread Starter #12
Update: two pry bars wedged between the brackets did the trick! I may still try to remove that snap ring from the inside bore to disassemble the caliper further but if I can't, hopefully this is enough for my powdercoater to work with. If I do get it more apart, I'll post the results here. Thanks everyone for the help and suggestions!
Under all the heat, road salt, abrasive brake dust, etcetera, isn't interesting how well the glossy red paint holds up on these calipers?
