Rear Engine Mount Question
Are the rear engine mounts the same in the non turbo versions of the fiesta?
Essentially the are the same as long as they are for the manual transmission.
They do NOT fit the Powereshift Automatic.
Ford made a slight change to the brackets in 2014.
So for 2011 - 2013 they are the same and 2014 & 2015 are the same.
A lot of companies make it for the FiST and that one will fit all '14 & '15.
I believe only Steeda makes it for all '11 - '13.
All that being said, I am using a Steeda on my '14 FiST, but it was not as Plug-N-Play.
I hope this helps.
Dave
JC1378
So would one from a 11-13 work on a 14?
Mine did.
However you may need to knock the metal inner tube off the '14 bracket.
Dave
