Redline MT-LV
Redline site says it meets Ford spec. BITOG forum agrees: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5144795 Anybody else try it? What do you think?
Drained the factory fluid at 900 miles. Glad I did, pan full of glitter. Made a small dipstick out of wire and verified factory fill level before draining. Hard to read but appeared to be slightly overfilled from the 1" below fill hole spec. Redline readily available, $27 for 2 quarts over the counter. Pumped the entire 2 quarts, again hard to read but on the stick and not coming out of fill hole.
I want to like it. Have used Redline in my vehicles since the 80s, almost always night and day from factory fill. Ironically what I like about it is also what I don't like. Before the change would occasionally get the wrong gear. Wrote it off to cable shifter imprecision. With the Redline it's more of a direct connection, like I can feel the syncros through the lever, better but borderline notchy, like it's too thin. Might be why the Ravenol MTF-2 is popular, slightly thicker than Ford fluid. Before I dump it am considering mixing with MTL to increase the viscosity. Bottom line wouldn't recommend it as is.
I run the MT-LV in mine. It is slightly thinner than the factory ford DCT fluid but I don't feel anything in the shifts that you are. I changed mine at 42 k miles so maybe the increased mileage and wear on mine makes a difference?
green_henry
I have been running MT-LV for several months; prior to that, I was running Red Line DCTF. Both work well, and I switched to MT-LV because the DCTF didn't claim to meet the same Ford spec (WSS-M2C200-D2). It seems to work great, but I wish the gearbox was quieter during shifting -- just the nature of the beast, I guess.
FiSTerMr
Taken from that BITOG thread:
"Many MT manufacturers have introduced fluid specifications for fluids with lower viscosities in the range of 6.0cSt@100C to 7.5cSt@100C, a viscosity in the same range as ATF fluids. These fluids were specified primarily to increase fuel mileage in order to raise fleet fuel mileage figures."
No surprise there, same as the engine oil... thinner for better MPG. But at what cost?? All the more reason to step up to the MTF-2, imo. For more protection. Same as engine oil, I use 5W30 (penz plat).
koozy
it's silly to compare viscosity or give anecdotal opinions on viscosity at room temperature and assume how it will perform in the gearbox at operating temps.
FiSTerMr
Of course, it's all conjecture. I am not an engineer/scientist/"oil guru".
koozy
I was referring to how it pours out of the bottle and compares to used OE fluid coming out of the gear box.
FiSTerMr
Well, VOA shows that ravenol mtf-2 is in the low to mid 7 cst at 100c, while the OEM is at 6.1 cst at 100c. And the Ravenol has an incredibly good low pour point temp of -51. That's about as good as you can get in this class of oils, from what I read.
Quisp
They hopefully made the gear contact faces more robust to handle it, much like a motorcycle with shared sump.
Sent from my SM-J727P using Tapatalk
FiSTerMr
The jump in viscosity is quite minor; for both the ravenol 2 and 5w30, as compared to stock specs.
Even if the jump in MTF was more significant, like Motul 300 (I believe it's in the 14.x range) would be perfectly fine to use, although cold weather shifting would be a chore until oil gets up to temp.
The most important factor with MTF is the additive/ep/anti-wear package it has; not only the right ones, but in the right amounts.
Remember, manual gearboxes are not under pressure, they don't have a pump that circulates oil.
Take a look at the MT-82 manual gearbox in the Mustang GT. It was originally spec'ed with "Honey", which is Ford's full synthetic MTF that is a 75W90, same like the Motul 300. They only changed the spec to DCTF due to cold shift complaints they were getting. Just about every older Ford vehicle either had "honey" as spec or back-spec'ed it in manual transmissions that originally called for ATF.
The use of DCTF is all about the fleet mileage standards these days, and cold weather shift smoothness; and in our cars, as has been hypothesized, to only need one oil on hand for various applications. Cost cutting.
As far as engine oil, well that's a no-brainer to me!
Our cars call for 5W30 outside of the U.S., so we know our cars can handle the added weight. The engine was designed with 5W30 in mind.
Ford's move to 5W20 across all platforms in the U.S. was done for CAFE standards, nothing else. It's a comprimise that they were willing to take.
2017 w/Recaros - bone stock
G
Drained a quart of the MT-LV and replaced with MTL, same chemistry only thicker. Better, no longer can feel the gears mesh. Think I can live with this. Feels like straight MTL would probably work fine as well.
FiSTerMr
I'm personally not a fan of mixing oils, but if it works for you, that's all that matters.
G
Yeah, not really a fan myself, done in the name of science. Confirmed my feeling that the MT-LV is too thin for this application even if it supposedly meets spec.Tried 50:50 first thinking this would be the most you would want to mix the heavier oil. Initially thought I would also try 25:75 MTL to MT-LV for two data points but the way 50:50 feels would want to go heavier if any not lighter. This feels good enough think I can leave it in there without fear of damaging the trans.
G
Thread Starter #14
Update: drained and swapped out for full MTL. Drove the MT-LV/MTL 50:50 mix through the winter, shifted Ok but seemed to be a bit better on colder days reinforcing my thoughts that thicker would be even better. Been driving several weeks since the change.Verdict: if you want to use Redline, MTL is the stuff. Shifts as well or better than the thinner fluid and finally can feel some lubrication film between gears, 1-2 notch is gone.
green_henry
I like Red Line products but I switched to Ravenol a few months ago for the transmission. The MT-LV also seemed a bit thin to me and I don't hear the transmission as much with the Ravenol
FiSTerMr
Ditto!
I've had great luck with ravenol MTF2.
Smoother shifts and less noise.
So, I just switched to BG synchro Shift (per Ron's recommmendation) and noticed some metal shavings in the old fluid. Is this normal or is my transmission on it's way out?
green_henry
That's normal on the first change. Hopefully you're not seeing it (or as much) on a subsequent change. I installed a magnetic drain plug to mitigate the issue.
Thanks for the input. I also installed a magnetic plug. I've read they don't do much, but I figured it couldn't hurt anything.
G
Thread Starter #20
Just switched to the MTF2 and won't be switching back. It's that much better. And this is coming from someone who has used Redline in everything I've owned for 40 years. And that just might be the crux of the issue, wouldn't be surprised if Redline chemistry is same as it was 40 years ago while syncro tech has evolved.
