- Member ID
- #1040
- Messages
- 669
- Likes
- 345
I just wanted to share where I was with my testing.
PROBLEM: Do not want to listen to music through the factory head unit.
SOLUTION: Go around it.
For those who like the factory look and all this is not going to feel good.
The only redeeming quality in my opinion about the factory unit is the Bluetooth for the phone.
That said.....
High Res audio files is where it is at especially in the car. With Hard drives in the 3 and 4 terabyte range, You could store just about your entire musical library in your car.
https://store.mp3car.com/
This is where the power supply will come from.
The computer will be based on the ITX form factor, Very small. You could go smaller, but you need a little more processor because you are going to be up scaling audio from WAV to something better.
I purchased a Microsoft Surface Pro 2 for the task for 250.00 but sold it because I wanted something different.
I went with the Ipad Pro 12.9 inch. I know big, but it does work right below the CD slot and above the AC controls. Now, start thinking movies.......with a big sound system to back it up.
I purchased a xDuoo XD-05 Audio DSD DAC PCM DXD Portable Headphone Amplifier 32BIT / 384KHZ. This is on Ebay. It is a portable Digital to Analog Converter. The gigabyte ITX motherboard has fiber out for audio, and anything that comes out of the ipad is digital so it needs converting. Why this DAC? It uses the AKM DA chip. While this may not be known to most, normally, the Burr Brown, or the ESS Sabre32 DAC are now very popular. The AKM in the audio world is the better sounding DAC and this piece is very small.
When playing HI RES audio on a computer, there is really only 1 piece of software to use, and that is JRiver. This is a music database of sorts, but it also plays and converts stuff to DSD level quality.
The ipad has a JRIVER Remote Control program that works over Bluetooth, or option two the Ipad has Remote Windows Access app that would give me access to the computer to control JRiver.
In addition, I am using a JL Audio Signal Source Y Adapter. What this does is allow me to use the FIX82 to grab the signal from the factory amp, so I can keep access to the Bluetooth car piece in the Sync system, and my audio will come from my computer in the trunk. This computer will be about 6" x 6" x 3" square. Very small and access to an extensive library.
That said.....
