- Member ID
- #5638
- Messages
- 4,005
- Likes
- 4,118
Now available from Silver's - A fully customizable coilover kit for your Fiesta with a few day turnaround
no hassle
build a custom set up for a great street riding Fiesta or a track beast...
and there are no additional fees involved![Rock On [rockon] [rockon]](/images/smilies/icon_smile_headbang.gif)
The Silver’s NEOMAX coilovers are independently height adjustable and come with an 18-month warranty.
• Mono-tube shock design, Increases shock oil capacity as well as displacement over twin tube designs for maximum performance.
• Adjustable T6 6061 front camber plates on all McPherson style applications.
• 24 levels of dampening adjustability combined with our high grade shock oil, not only do you feel the click in your fingers, you feel every dampening adjustment in the driver’s seat..
• High strength JIS G3445-STKM13C (DIN2393-ST44-2) carbon steel 52mm diameter seamless shock tube.
• 44mm linear characteristic internal piston provides maximum dampening response for ultimate performance while simultaneously giving a comfortable ride.
• High viscosity IP F.A. 5W damper oil ensures the best efficiency of shock-absorption and dampening control.
• Height adjustability is provided by the lower bracket which prevents the need to adjust the spring perch or preload, offering the maximum possible travel.
• Cold-bent springs made from high strength SAE9254 steel which keeps stable elastic modulus.
• Powder coated steel lower brackets matching all factory brake line & ABS wire tabs, for ease of installation.
• Anodized T6 6061 aluminum lower mounts for multilink suspension systems to lower un-sprung weight.
Default Spring Rates: Front 6K, Rear 5K
Link to product>>>https://whoosh-motorsports.myshopify.com/collections/2014-2017-ford-fiesta-st/products/silvers-neomax-coilover-kit-2014-fiesta-st-custom-spring-rates-available
stock photo / actual photos coming when stock arrives at whoosh HQ
no hassle
