SOS P2122 Throttle position sensor
Hello everyone,
I've scoured the web and this forum looking for answers and I'm stumped. Today I installed a powered subwoofer in my car. I ran the power cable through the symposer tube into the cabin. In order to do this I removed the battery, battery tray and PCM. Im running the sub off the rear channels which I tapped into at the b pillars. Once I started the car it ran fine. When i hit the throttle it would respond for a second and then stop. It then threw the p2122 code. I pulled the battery, tray and pcm out again to make sure nothing is loose and it all looks fine. Any Ideas? Any help would be appreciated, thanks guys!
B
Thread Starter #2
I'm going to add what I've discovered so far tonight. If i press the brake after the throttle stops working it will work but the car is in limp mode. Tomorrow I'm going to have to pull out a multi meter and see if I have a short somewhere. Currently I'm under the impression I've somehow damaged the wiring harness, which surprises me because I was EXTREMELY careful while under the dash. [mecry]
Did you ever find a solution to this? I’m having this issue now after pulling the battery box for a trans mount install.
