Sos!
So every time I pass 35-4K, I get a loss of power followed by a louder spool from the BOV. The engine light occasionally comes on and eventually goes away but the the code reads as an “overboost”.
Thank you!
V
Thread Starter #2
*3-4K rpms
Stock? Tuned? What'chu got? How many miles? If you had an accessport, it would be nice to know what boost you had and the waste-gate duty cycle. Those two would basically tell us what's going on.
There's a few reasons for over boost. Boost control solenoid mounted on the turbo has three hoses connected to it, leading to the: intake, hot-side, and actuator for the waste-gate. Could be straightforward if you waste-gate isn't controlling boost properly...can get the vacuum lines damaged if you get debris up there. Do any off-roading recently? :p
You have two boost control devices. Wastewater and BOV (diverter valve, if stock). Something is amiss.
Edit: Said actuator without waste-gate. Don't want to confuse.
felopr
i bet is it is tuned, not a ots one but from a flash tune. If it is overboost then you are passing the upper load threshold on the tune (cold weather can do that) just talk to your tuner , he will fix it
