- Member ID
- #5968
- Messages
- 55
- Likes
- 38
Delete/lock. Sparco Seat install + Airbag bypass. '16 FiST
Passenger seat install is on Post #42 thanks Genya or click the following link :
http://www.fiestastforum.com/forum/threads/14529-Sparco-Seat-install-Airbag-bypass-16-FiST?p=275436&viewfull=1#post275436
*** Please do this airbag sensor bypass at your own risk. I will not be held accountable if anything catastrophic happens when doing this install. PLEASE USE COMMON SENSE
***IMPORTANT*** PLEASE DISCONNECT YOUR BATTERY DURING THE INSTALL.
**Just in case photos aren't working I created a shared folder in Google drive **
https://drive.google.com/drive/folders/0B7P5OT01OdkFU2VfUzAyRWtQWWs?usp=sharing
Finally got around to install my sparco seat on my 16' Fiesta ST
** List of parts used during the install**
-Seats:
http://www.sparcousa.com/product/r100
-Base: Planted Technology base
*It will say out of stock sometimes. These are Built to order, takes about 7-10 days to build then ship afterwards*
*Some drilling is required depending on how your mounting it up. I did have to drill 2 new holes as I did not opt for rails at the time. If you purchase the rails you may not need to drill.*
http://www.plantedtechnology.com/pr...ket-ford-fiesta-mark-vi-2008-driver-left.html
-Hardware
Street series seats require the #50001 kit)
http://www.sparcousa.com/product/hardware-spacer-kits
-Resistor(s)
2.2 OHM resistors (2 red bands + 2 gold bands) 1/2
https://www.amazon.com/gp/product/B01F5F57OI/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
-Rail sliders:
https://www.amazon.com/Sparco-Slide...coding=UTF8&psc=1&refRID=K5NVESW7M22Z72AFV0FT
Various wires and extra bits
**Torque Specs
-Torque specs that anchor the seat to floor board is 38nm.
-Seat belt / belt tensioner is 53nm.
1) First remove seat bolts, there are 4 bolts. It helps to move the steering wheel in and out. Also slide the seats far forward or back to help get to the bolts. Lift off slowly and disconnect the one connector located on the Driver door side
Front Bolts
Rear Bolts
2) Clean up all the junk under your seats while you're at it -_-
3) Test fitted the Bracket from Planted Technology
4) Here is a view underneath the seat. Make note of the highlighted / circled connectors.
5) Wiring up and bypassing the Airbag sensor.
you would need the 2.2 Ohm Resistors linked above.
Wiring it up should look something similar to the photo below.
*Note* For the air bag connection. I measured it at 2.1-2.2 Ohms. I ended up splitting a spare wire and soldered one 2.2ohm resistor then used vampire clips.
* You can at this point once everything is connected (air bag sensor, 2.2 ohm resistor, & seat belt sensor, & main connection) you can plug the battery in and turn the car on to accessories. Air bag light will show up and then disappear. If you really want to you can start the car you can ( not needed). *** Important*** disconnect battery when your done testing and making sure your connections are solid.
6) Mount the Airbag sensor to a sturdy location. I ended up just drilling a smaller hole and used self taping screws to secure the sensor. I then further covered it up with bubble wrap ( not needed, but iono just for kicks ?)
7) Encasing the Airbag connection w/ 2.2ohm resistors in a Altoids box. I later then zip-tied it to the rest of the bundle of wires.
8) Install the seats + brackets. Connect the wires etc.
9) Results: Tested and drove the car around no Airbag sensor light. The seats w/ base and no rails drops you pretty much 1 " off the mounting points. I would advise for seat rails. A friend of mine who is about 5' 5" sits comfortably. As for me being 6'2" @250lbs it would've been nice to sit back a little bit ( ended up ordering rails coming in later ).
-Seats:
-Hardware
-Resistor(s)
-Rail sliders:
**Torque Specs
Front Bolts
Rear Bolts
