Steering issues after driving on dirt road - alignment or tire balancing?
Los Gatos, CA, USA
I went to a wedding over the weekend and unfortunately the last mile or so to the venue was on a pretty rutted out dirt road, which was not ideal for my FiST. I took it as slow as possible, but the road was definitely harsh despite my care.
Since then, the car feels a bit "looser" than before. Steering doesn't feel as tight and direct, and I'm getting a decent vibration through the steering wheel when I'm above 75ish mph on the highway. Car seems to track relatively straight though if I loosen my grip on the wheel.
I booked an alignment for this afternoon, but I don't want to waste my money. Is this likely to be an alignment issue? Or should I look for wheel balancing first? Or could it be something different in the suspension all together? Thanks!
Suwanee
torn bushings, wheel weight kicked, failing tire from an internal belt breaking from a rock... all things that can cause what you're describing. alignment is probably a good start though.
