Sway Bar
Glendale
Hi, I own a 2014 FiST with the ST suspension coilovers and am not sure if I should get any sway bars. From what I know, the stock 2014 has a front sway bar and a torsion beam rear axle. Would it be worth buying a sway bar for front and back, just back, or leave it stock? Any brand recommendations would also me appreciated, thanks.
Clyde
What is it you are trying to change about the cars handling? This will help people in making suggestions (if any).
For example, I wanted more/easier rotation on the track (I have BC coilovers with Swift springs, but should be fairly similar) so I have a Pierce Motorsports rear beam brace (mounts inside the rear axle beam) and a Whiteline 22mm rear sway bar, left the front stock but threw in some poly bushings.
