Symposer exit location in cabin?
Ridge
My first post but I have been sifting through threads for a while now. Anyhow I picked up the idea of using the existing tube from my symposer delete to run wires through for my meth injection, but I can't find any other info as to where it exits? If somebody could fill me in I could get cracking on the install.
JPGC
Middleburg
It exits behind the dash almost in the center of the car if you look up past the gas pedal, you will see it. The tube doesn't connect to anything, it's just there, lol. I used mine, after I deleted the symposer, to route my wiring for my ethanol content analyzer. The easiest was is to cut the tube near where it enters the cabin, inside the cabin above the clutch pedal and use the clamps that were holding the tube to route whatever wires you are routing.
