TB Performance Rear Torsion Bar
I got my TB Performance rear torsion bar yesterday and I got it installed last night. It was the easiest install I have done to my car so far. Really high quality and a nice note from the owner. I was a little skeptical about how a small bar can help that much on cornering. I took it out and immediately felt the difference. In corners I feel way more confident and the car feels so planted in the rear. I highly recommend this mod as it is inexpensive and really does help in the corners!
Does the bar add more oversteer? Understeer? How has it improved? Just feels more solid?
L
I installed one 2 weeks ago and it made a huge difference. Did you add bushings to the bolt holes?
I did not add bushings to the bolt holes.
Sent from my XT1585 using Tapatalk
L
It still oversteers but you have to push harder and it's more controlled. It definitely feels like the rear end is more solid. It gives you a lot more confidence in the corners.
LilPartyBox
I have the Pierce. For the most part, same shit different logo. :)
They both perform the same basic function although I find PMs design a bit more thorough. Reason being their bar's edges are radius where they meet the beam for a more secure fitment. And they have two additional contact points per side to prevent any lateral movement, however small. And it's made from chromoly which I know from my bicycle days is strong and light. Whether any of this makes it a better bar than TBs is up to you. I thought so and spent the extra 50 bucks.
