Track Day Brake Mishap :( Brake duct ideas?
Chuckable
It may be a bit of a tight fit and the outlet and what it runs into could be a serious issue as well as they are designed for mostly flat surfaces but still would flow pretty well.
Perhaps the one in kevin...post would work out easier to use.
Makes sense, plus as others have said, why not cut up the OEM air dam given that it's substantially cheaper than the bumper cover.
kevinatfms
The air dam does function but creating a path for air to flow to cool the brakes shouldnt add too much turbulence to the under car area. I would be more worried about track boogers getting "shot" into the hub, caliper and rotor.
If i ever get a chance to mod something up i will make it easy to remove. Example: Unclip air dam, remove hose from backing plate, pull zip ties from control arms(used to secure hose) then install the stock air dam back on.
You talking to me?
Google is my friend:
993 Brake Air Deflector - Right Front (993-341-084-00) -- http://www.5150motorsport.com/993-brake-air-deflector-right-front-993-341-084-00/
993 Brake Air Deflector - Left Front (993-341-083-00) -- http://www.5150motorsport.com/993-brake-air-deflector-left-front-993-341-083-00/
I suspect you can find these a little cheaper with a google search of your own, but I found the right front on my initial search page, then poked to find the mate.
I just ordered these, hopefully they come in time before my HDPE event on the 22nd!
