Bought this...
https://www.amazon.com/gp/product/B01BW39HJS/
...pissed away half a weekend fooling with the defective Venturi adapter.
Bought an actual vacuum pump and still had issues.
Wouldn't hold pressure or vacuum.
Found the source of the issue...
...That's the coolant overflow drain. Excess coolant that presses its way out of the spring-operated valve in the cap, drains down this slot.
None of the little adapters on the tool account for this.
I have perfectly sized O-Rings but there's no way to press the o-rings into that slot hard enough for them to seal.
The cap, seals on the inner-circumference rather than on the top-surfaces there.
May instead, require an adapter that looks more like this...
Before I go looking, has anyone already found and used such an adapter with their Fiesta?
