- Member ID
- #7636
- Messages
- 1
- Likes
- 0
Hi guys just going to shed some light on this topic yes you can fit an navigation system into St and yes you can have reverse camera aswell with or without nav
If you want to add oem navigation to car all you need is a
nav fcdim low module display
Sd card with maps loaded
Gps antenna of eBay with fakra connector
A control fascia panel with nav on it or you can use your existing panel in the same way
Just unplug original screen and install nav screen you will notice your odometer will go from miles to km but that can be fixed by
Using forscan licensed and change display from 4" to 5" nav and it will go back to. Normal also you need to attach an wire to make directions audio work between nav and stereo connecting lead pin 4 stereo to pin 12 on display and pin 5 on stereo to pin 6 on display
If you choose to have reverse camera on the nav you will need a lead converts from 4 pin hsd connector to av lead and you must make sure you buy a rear camera that is ntsc format or it will not work run the wires from front to back of car with a universal kit
If you want to add reverse camera without nav you will need to connect to pins 12 ,11 ,6 on the original fcdim display with the universal camera kit
Also you have to activate it in forscan
