Vacuum Hose Diameter.
slopoke
Livermore
I'm getting together all of the small parts associated with the turbo that I will be installing. What is the size of the vacuum hose that's on the turbo for the waste gate and solenoid? Also can the same diameter hose be used on a typical boost gauge? Thanks.
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
You’re probably going to need 6mm (1/4”) inner diameter. Summit Racing carries Turbosmart which is really good vacuum hose.
