Vent to atmosphere catch can
I got this vta catch can in my parts collection. I originally bought it for my turbo Honda project but never used it. It has 2 5/8" inlets and a 1" outlet. Does anyone know how I can make this work in the fiesta's pcv system? The fiesta seems to be a system completely under vacuum.
You are correct....the Fiesta is under Vacuum....you would need to get the ends that go into the valve cover and some hose. I'd also be replacing that petcock style radiator drain with a ball style with a push lever to make draining easier if you place it near the strut tower and utilize its mounting points for that purpose.
You'll also need to put a check valve on the breather filter, otherwise you are introducing a leak into the crankcase.
