Wastegate map in race tuner adds "0's".
Sourskittle
I'm been messing with the boost in my car ( the epic battle between more timing with lower boost or higher boost with lower timing ). And some times when I edit my tables, they change perfectly normal. And then i run the car and it just falls on its face. Check the log, find out that it dropped 8psi off where it was supposed to be more or less steady. Open up the tune and... I see this.
It just sticks 0's in the middle of the map !! Its done this 4 times now... Totally weird...
me32
How dose the map look before you load it?
Sourskittle
Sourskittle
When I save the map after editing it, it turns green like the rest of the numbers. If I reload the map right then, it puts in the zeros like that. But if I don't check it every time I change the map, It can trick me.
