I purchased my performance blue Fiesta ST in February 2014. This is my daily driver, so I need to keep the mods simple in the beginning. I have a 2011 Mustang (3.7 supercharged) that is my race car build, so most of my money is going there. But modding is my favorite hobby, so until my Mustang is done, major mods on the fiesta will be only stage 3 power nods.
I live in So Cal (Riverside) and drive 70 miles per day so exterior mods were my first mods. I had my front end covered in 3M clear bra and my windows tinted, also 3M ceramic.
Ended up having to remove and replace the film once.
Legal tint (sorta)
Next steps were to remove all of the scratches everone, including the dealer, added to the FiST. So I did a complete detail, washed and de-ironed the paint, used a clay bar, then taping everything off, and using wolfgang swirl remover, menzerna powerlock, and then sealing off the paint with Sonax polymer netshield. I used a Girots garage 6" buffer with lakeside pads.
Next up was a mountune intake and a painted engine cover.
I also added a mountune air box. I painted it black and painted the screws black to match the OEM air box.
Next up was an oil change qt 1000 miles. That oil filter was welded on. I also replaced the oil change plug with a fumoto valve. F106N is the correct part number.
Once I had another 5000 miles, I changed the oil (Motorcraft semisynth and motorcraft oil filter) and sent some oil to Blackstone labs for an oil analysis.
My next mods were painting the brake calipers and disc rotors.
Then I added a mountune short shift kit.
I purchased a Cobb AP so I decided to mod the interior to mod a mount to locate the Cobb AP. I trimmed the mount to move it up on the mini window, then hit it with a butane torch to further bend it up. I also added a OBDII entension cable and hid everything under the dash.
I added a Ford mirror with auto dimming, compass, temperature, and homelink. I also added a blend mount to attach my Escort 9500ix radar detector. I purchased a direct wire kit for the escort from ebay and wired it to the fuse block.
I added dmbgraphics gel labels (red and black) to the steering wheel, front and back hoods. I added an ebay mondeo blue ST badge to the right side
I added two shifter bars, one a Cobb knob that I painted blue. It felt too light, so I went with a Breedt blue ST ball
Then I added a hood strut kit today. This was purxhased from SiCo development in UK for $120.00. Its a little pricy, but it works well, and is well made. Instructions have tiny pics, and you need to loosen the remote brake fluid reservoir to get the bracket in, but that is the only additional srep required. Tuck the negative battery cable away until you need to put it back on to prevent sparks.
Ready to install
Remove this bolt to make it easier to install the bracket.
Bottom bracket installed
Installing the clip on the lower part of the gas shock.
Top mounting point on hood. Uses a split c washer/
Gas strut installed on top ball.
All done
Next up, Mishimoto catch can with OEM hoses, a Levels intercooler, and either the Cobb exhaust or the Mountune exhaust. Once they're done, I'll add my HID projector headlight homage to the concept Fiesta ST.
Legal tint (sorta)
Ready to install
All done
