wheel size and your odometer
DaveG99
Dallas
Installing a smaller diameter tire will cause your odometer to read more miles than normal correct? That would not be good if its a large difference. Is there a way to fix this electronically?
Buffalo, NY
I know on my SVT focus accessing the gem module and the pcm with the OEM ford programming set up with a J2534 tool you could actually change the calibration for tire size.
Havent had a chance to see if that an option on the FiST yet but that would be my only guess unless someone has figured it out in forscan.
HardBoiledEgg
Fontana
I wish I knew people who could use this Forscan I keep hearing about. Turn off my shift light and fit my tire size
DaveG99
DaveG99
Dallas
The AP should be able to do this stuff right?
XanRules
Portland
the difference between a 17" wheel with a 205/40/17 and a 16" wheel with a 205/45/17 is 0.9%. Not enough to worry about IMO.
