I might take you up on that
I am changing how I set my front camber from the strut tops to the coilover/knuckles and am test fitting spacing the wheels out far enough to clear everything, 15x9, +35mm
Right now I am using some 10mm spacers and stacking some 2mm plates but need thicker ones behind them so more like 15mm and machined to fit the wheels I run with a bigger hub bore than the ST wheels. Better to have one piece instead of three doing the job.
I already have ARP studs installed all around so good to go there.
The wider track up front will aid in reducing body roll via leverage instead of sway bar or springs which is better done right and probably bring me closer to the stock scrub radius than I have now which is a bit less than stock.
I would like them machined to take out some weight where it can be safely done.
Let me know the expected cost, delivery time, etc and if any questions, I can figure this out in the next day or two.
Thanks
Rick
