Wing risers fading.
Trader history for DAPR (0)
DAPR
Had my red risers on for a few weeks and they are turning pink and looking gross. I purchased from Boomba to support the company that designed the part. I think I made a mistake, other companies powercoat and their products are probably more durable. My shift knob still looks fine, I'm nervous to open my hood and check my battery hold down.
alexrex20
Where did you buy it from? Reputable vendor?
D
DAPR
Direct from Boomba.
jeff
Dude, tape it all off and use a high quality spray paint to fix it. That's $5 and will take 30 minutes as opposed to removing the entire assembly for a replacement. Easy fix.
Boomba is top notch, you might have gotten a lemon, but it should hold structurally.
alexrex20
Take off the spoiler and the trunk so you can spray paint it? LMAO yeah, that is so much easier than just removing it and spray painting it while uninstalled.
Sam4
Yeah, my boomba black are now purplish, but no way would I uninstall to paint - forget painting in place.
jeff
Painting stuff in place isn't that hard. Get a roll of 3" masking tape and some newspaper, a little careful prep work and you're good. I've done it a jillion times, if the piece in question is easy to remove that's one thing, but in the case of the Fiesta rear wing it would be far quicker to paint the risers with the wing on.
alexrex20
It's 6 bolts.
D
DAPR
I'd take them off to paint. But spending $140 on these I expected to quality. That's not what I got. I should not be responsible for painting them or doing QC for the company.
alexrex20
Agreed. I'm surprised they're not anodized.
Jerickson88
Anodized parts fade in the sun. Powder coated will as well if you aren’t using a UV rated paint.
Jerickson88
Anodized parts fade in the sun. Powdercoated will as well if you aren’t using a UV rated paint.
https://www.anoplate.com/news-and-events/why-does-anodize-fade/
Not defending the company. Call them and give them a chance to make it right. There’s also nowhere that states they will or will not fade in UV exposure.
Do you mind posting pictures? Try tinypic.com if you have issues with the forums attachment tool.
D
DAPR
Thread Starter #13
People in the first run had issues like this as well. I just think the anodized parts were not properly sealed. I really wanted to order the cheaper ones from another vendor and was torn on the issue. I wanted to support a company that supports the community. Looks like I may have chosen poorly this time. I called them and they asked for pictures so hopefully I can get that to them shortly. If I'm not satisfied with their resolution I'll buy a set from another vendor, paint the Boomba ones and sell them to someone else. It's sad because I really like their offerings.
I'll hold further judgement until I see their resolution.
D
DAPR
Thread Starter #14
They started in a previous thread that fading was not an issue.
To quote Boomba directly:
"The first batch of wing risers had a fading issue only in the black and red color. The anodizer we used failed to properly seal the risers, resulting in them fading very quickly. Since then, we have switched anodizers and the issue no longer persists."
Jerickson88
10-4. I don’t use anything of theirs, but have handled their parts, it’s quality. Things happen. I’m sure they will make it right.
D
Thread Starter #16
"1-You can send the risers back to us and we will have them re-anodized for you.
OR
2-We can offer you a discount on your next Boomba purchase.
OR
3-We can send you a Boomba T-shirt in your choice of size or a Boomba beanie."
Boomba just lost a customer.
D
Thread Starter #17
The T-shirt offer feels like a slap in the face. Why would I want to advertise for your company after getting a bad product. Makes me want to remove all my Boomba part's. I had recommended their shift knob to someone. Hope that doesn't bite me.
Here's what they look like in under 4 weeks.
You should see mine, way worse than that. Black is now silver. It is what it is - doesn't bother me
D
Thread Starter #19
Welp seems like they never fixed the issue. Did yours turn in under a month. It hasn't even been 4 weeks. Should of just bought the ones on Amazon.
I've had them over 2 years now, pretty sure by mid summer (I Bought them in May 2016) they had already turned
