Hate to bump this, but was anyone able to successfully complete this on a newer Fiesta ST with the single piece fuel line. I can't see the fitting at the HPFP without removing the cowl, battery, and intake and don't want to do so until I know I have all the correct parts. It looks like the whole line is one piece with no disconnect fittings at the firewall..
Hey JDG, yes I just did this and was planning on posting to this thread once I refined my install just a touch.
The fuel line on the late model cars (mine is a 2017) does not detach from the steel line. However, it is not necessary. You can just disconnect it at the QD at the Hardline that connects to the fuel rail. That OEM line is long enough to use as it is to connect to the flex fuel sensor.
With that said, the parts list is a bit inaccurate, and the Flex lines listed to buy from radium are not ideal. I currently have the setup working will in my car, but I am going to be changing the under hood installation more to my liking.
I am waiting on parts and will share in a post next week.
The gist of it though is that I'm going to be making my own lines with some stainless ptfe line and fittings to get the exact lengths I want to mount the sensor to a bracket I'm going to pop rivet to the firewall.
The fittings listed by series80 are needed to attach to the end of the OEM fuel line and attach it to the sensor.
The Russell 640930 goes into the OEM QD line, then the Russell 640003, then the Russell 644113 which attaches to the sensor.
I'm going to swap to a Russell 611253 to eliminate a coupler (eliminate the 640003).
