Cobb Accessport Launch Control
felopr
JD
Where should I set my Accessport Launch Control for the best launch using stock tires on dry asphalt? Cobb's 4000 RPM preset seems a little too much, I just smoke the tires all the way through 3rd. https://www.youtube.com/watch?v=zgFF9e06BRE -FF to 1:09.
imo i think 4k rpm is to high for the streets too, would be good on a drag strip since the asphalt is very sticky.
you could always ask if you ever go for a protune, for 1 slot have it at 2.5k rpm for lc in the streets and in another slot the 4k lc for the dragstrip that would give you a base line and then further down the line dial the rpm to a better rpm.
i dont think cobb would change the ots tune for a custom lc rpm setting. i could always be wrong
Sourskittle
Lakeland
Mine set at 2800rpm with the modded turbo. And I have the wgdc dropped in 1st and 2nd gear.
