Waterjet cut 3/8" thick aluminum gas pedal lift spacer for the Fiesta ST. It comes painted black and included 2 serrated flange lock nuts.
From the factory, the gas pedal is much lower than the brake pedal which makes heel/toe shifting a bit difficult and awkward. The spacer lift is subtle, but its just enough that I noticed a definite improvement in my heel/toeing.
The Fiesta ST gas pedal lift spacers are $29 shipped for USPS first class or $32 shipped for USPS Priority.
Just reply to this thread or PM me if you are interested in purchasing one.
Installation is very simple. Use a deep 13mm socket to remove the 2 nuts holding the gas pedal down.
Then you slip the spacer over the studs in the orientation shown below. Next slip the gas pedal back over the studs sandwiching the spacer and install the new serrated flange lock nuts.
