Well, here it is.
I finally made the time to install that front bar. TB's Torsion bar was quite simple and took no longer than 20 min on the ramps. TB's all new Traction bar looks to be a cinch to install. As I mentioned in a previous thread, the suspension bolts do not have to be completely removed, just loosened enough to slip the bar in. However, for me, it was more of a challenge with loosening the suspension bolts. Regardless, I took it to a local shop and they charged me $20 to install the Traction bar(and rotated my tires).
What's it like to drive?
I'll tell you up front, IT'S NOT AN ST ANYMORE! It is certainly something MORE. The levels of grip and balance are unbelievable now. It reminds me of the balance I used to have in my E92 335 with corner balanced KW V2 coil-overs. Simply amazing. And for less than $200, IT'S A STEAL! Keep in mind, these are the only mods I have on the FiST thus far and as far as I can see, I will not need to be doing anything else to the suspension. That good!
I've said before, this car does not rotate as much as the FoST, but on the other hand, it's much more predictable now. Throwing it into a turn can now induce controlled 4 wheel slides, flipping brilliant!
If you have a FiST, then you MUST get these parts from TB, NO EXCUSE! Danny @TB has always gotten back to me with plenty of information in a timely manor. And the personally signed letter adds a nice touch.
Enough of the talk, let's see some pics of the new gear.
