Stock alignment specs
Does anyone have the stock alignment specs? I installed Eibach springs over the weekend and want to make sure the tire shop doesn't use base model Fiesta specs when checking the alignment.
Thanks for the info.
Young L
good call. ima about to do the same thing but with H&R springs
I can't remember the toe-in/out but camber for my driver side was -0.9 and passenger side was -1.5. Mind you this was after 15000 miles.
BRGT350
Front
-1.18 +/-1.25 camber
4.08 +/-1.00 caster
0.20 degrees +/-0.20 degrees toe split (positive toe in, measured at curb ride height, full tank of fuel)
Rear
-0.64 +/-1.25 camber
0.00 degrees +/-0.50 degrees toe split
Here is the complete chart from the Service Manual.
Just in case you need more info or wish to make a comparison.
Fiesta Alignment Specs
Dave
Tex ST-AR
Thanks Dave, your a wealth of knowledge. Or maybe you just know how to work the internet better than me either way [twothumb]
