Does anyone have the stock alignment specs? I installed Eibach springs over the weekend and want to make sure the tire shop doesn't use base model Fiesta specs when checking the alignment.
Thanks for the info.
Front
-1.18 +/-1.25 camber
4.08 +/-1.00 caster
0.20 degrees +/-0.20 degrees toe split (positive toe in, measured at curb ride height, full tank of fuel)
Rear
-0.64 +/-1.25 camber
0.00 degrees +/-0.50 degrees toe split
