Keep your intake clean! Ford Fiesta ST Oil Catch Can R&D by Mishimoto
JPGC
Middleburg
[MENTION=1848]mishimoto[/MENTION], have you gotten the red hose kits in off of back order? The lady who called me last week said that you should have them on the 8th. I'm just seeing if you have shipped those. Thanks
Etyrnus
Nowhere
Just emptied mine for the first time last night. Roughly 1000 miles since install. There was maybe 1/2 teaspoon, probably more like 1/4 teaspoon of oil in the catch can. Definitely glad to not see more, but glad I have the catch can for what there is!
M
mishimoto1
New Castle
Thread Starter #207
Neither of those will work... the hoses are 5/8"
'Doh!
Off to eBay I suppose...
ETA:Aluminum 5/8" Check Valve
Thanks for the answer! This is correct the hoses are 5/8
The best way to check on this would be to give our customer service team a call at 1877GOMISHI (their hours are between 10am and 6pm). They would be more than happy to assist you with this as I do not have access to your order information. If you need anything else let me know!
Gonna check mine soon. What's the best way to get to it? I was thinking removing the headlight.
If the can is tight that is the best/quickest way.
Removing the headlight is one way to do it! There are a few ways to empty the catch can so you have a couple options to choose which will work for your Fiesta.
Thanks for the feedback! Glad to see the catch can is doing its job!
-Sara
Houston
I've had the Mishimoto can on for ~800 miles and about a month now. I decided to open it up to see the accumulation. To do this, I removed the passenger side headlight. Three bolts, took me about 3 minutes to get the headlight out including time looking for tools. T30 torx bit and a phillips head
screwdriver. THen there is plenty of room to stick your hand down there and unscrew the OCC.
The good news is that there was a small puddle at the bottom, but no serious accumulation of oil. Which is to be expected, I guess. The good news is that the catch can is catching oil, and the better news is that it is not catching that much oil, either. This means that despite the Mishimoto can being smaller than some of the other options out there, it doesn't really need to be that big.
I'm interested to see if accumulation increases as we get into the colder months of the winter.
M
mishimoto1
New Castle
Thread Starter #209
We really appreciate the feedback and are glad that you're pleased with your catch can! What you are describing is about as much accumulation as we saw during testing, so you seem to be right on track with what we found. Thanks for sharing!
-Sara
Miami
Catastrophic failure of catch can after 2396 miles. I went to drain it and discovered it hanging by the hoses. Mount has sheared off.
It did catch oil though...
Mishi....?
BoostBumps
Arizona
^^ OUCH...Sorry to see this!
I actually raised this as one my main concerns with mounting an OCC bracket to engine mount about 3 months ago in another thread....
Hopefully there is an easy solution...
J2FoRS
Central
Wow wtf.
I still haven't installed mine as I don't have a draining solution yet. I'm debating just selling it to be honest. Your thread has now definitly made me lean that way.
Miami
To be honest, it did it's job as far as catching oil, it's just the mount is not robust enough. My mechanics are confident they can custom fab a stronger, better bracket.
M
mishimoto1
New Castle
Thread Starter #217
Mishi....?
Hi Mercdank,
I apologize for the delay! We are very sorry to hear about that failure. This is the first time we are seeing this issue, but as we speak, our engineers are doing their best to find an immediate fix to the problem. In the meantime, let's get you back on the road. Send us a PM on here so we can get a brand new bracket sent out to you ASAP!!
[MENTION=1848]mishimoto[/MENTION] is there any oil catch can I can use for a 1.5L ecoboost engine?
We don't have a direct fit kit for the 1.5L right now, but we have a universal catch can that should work just fine.
Wow wtf.
This has been the first time we've seen this happen, but the catch can does its job well. We are working to remedy the situation, but hopefully we don't see this again!
Rest assured our engineers are working on a solution!
J2FoRS
Central
I have no doubt your can itself works well. I've used your other cans before. I just was hoping for the plug and play easy accessibility and Mishi quality I expected. So far 1 for 3.
westcoaST
Corona
Based on this photo, it looks like the outside radius of the bend is contacting the passenger side engine mount. This would tend to transfer vibrational stresses into the OCC mount. Slotting the holes that attach to the engine mount, and pushing the mount away from the corner shown as burnished in the photograph should eliminate the fatigue loading that appears to be responsible for the failure. A photograph of the fracture face would be helpful to tell if this is a fatigue failure. Perhaps even pushing the mount away from the corner, without slotting the holes would be enough to prevent failure.
CanadianGuy
Southern Ontario
I was thinking adding a gusset would also help relieve the stress along the axis and add strength.
