CFM Performance now makes it easy to vent the crankcase on your 2013+ Focus ST & Fiesta ST with our billet valve cover baffled breather kit. This kit is a direct replacement for your factory oil fill cap and allows unwanted crankcase pressure to exit.
This breather is the ONLY one in the market which incorporates a check ball to keep unmetered air from coming through while the crankcase is under vacuum. In other words, this breather acts just like a factory oil cap under normal driving conditions and when you get into boost it will release any crankcase pressure present. Along with the check ball we have integrated a baffle system in the breather's base. This isn't your old fashion conventional breather!
The factory PCV system as you know is quite a small port to vent the crankcase when compared to the oil fill port. The CFM valve cover breather along with a dirty side PCV Oil separator will work amazingly to vent your crankcase and stop contaminated oil particles from entering the intake system. We HIGHLY recommend the Mishimoto Oil Catch Can for the Fiesta ST, available at CFM Performance.
The filter element is washable and we offer a variety of color options for the top. Although this kit was designed for use in racing applications, it works and looks great in any engine compartment.
Head over to our site to pick up your CFM Performance Valve Cover Breather
