Cordova motorspots optimized throttle bodys for 1.6
me32
fairfield
http://cordovamotorsports.com/cgi-bin/CMS/shop_mastr
So i found this site on one of the ford fusion sites. This company appears to optimize the ecoboost throttle bodys to gain a 15% more air flow. Has anyone looked into this for the fiesta st? I notice there isnt alot of options for throttle bodys for the FIST.
TheStig
Phoenix
I dont know if it would really make that much of a difference but I may be wrong. Perhaps with a big turbo.
me32
me32
fairfield
It seems the some of the guys in the fusion site have reported a notice in a throttle response and low end tq and top end hp. Most were ones with 2.0 and couple with 1.5.
me32
me32
fairfield
Does anyone know for sure if the 1.6 ecoboost throttle bodys are all the same? I have contacted the company about it for the FIST but he was not 100% sure and was gonna do some research.
frankiefiesta
forked river
No I'm not sure but check this out. A 3.5 ecoboost 72mm bored out throttle body made by bbk and a picture of the 1.6 fusion throttle body. They look pretty similar. I wonder if the 72mm could be made to work
me32
me32
fairfield
That is interesting. Are the plugs the same? The bolt pattern look very close
Victoria
Keep us in the loop about what you find out. Is it actually larger? If so I'm guessing you would need a custom tune to see its full potential.
me32
me32
fairfield
Wil do. It does not bore out the throttle it takes out what can block or reduce air flow through the stock throttle body. It does not need a custom tune. But a custom tune would get more gain from it.
frankiefiesta
forked river
me32
me32
fairfield
AncaSTer, Ontario
Did some more searching and take this as you will. Both the fiesta st and fusion 1.6 ecoboost throttle bodies use the same part number. Chances of them being compatible are pretty good.
http://www.fordparts.com/Commerce/P...&search=true&year=2014&make=Ford&model=Fusion
http://www.fordparts.com/Commerce/P...&search=true&year=2014&make=Ford&model=Fiesta
Both use part number 9E926
The second one's web address says Fiesta, but the actual page it brings up says Fusion, as does the first.
