Hello, I would like to share my bed experince with those tires. I used them only for 1500 km (about 1000 miles). They have better grip than potenzas and I heard a lot of good experience with them. Some friends have them still and no problem. Up to now I used stock potenzas 205/40/17 and adhesion is not so good I need. For example rear pair died after one circuit experience (but before it there were on front wheels and they tolerate stress in 4 slalom tracks without big problems - it is normal, that every slalom means 1,5 mm of tread down, but no problem with side walls). So after this circuit experience I bought 4 Pilot S3. I gave Potenza from front wheels to rear wheels and new Pilots to front wheels. 1000 miles on roads and than one slalom. Only one...and this is result of it. Holes in sidewalls. :-( Tread stayed at about 7 mm! As you can see, there are no writing, there went totaly down. After maybe 15 minutes on the slalom tracks. There were 30 other cars and nobody had this problem. The surface was very nice - flat and soft. But the sidewalls are really incredibly weak. :-( Maybe only very bed series, but I can´t trust them after this experience.....
And in this photo you can see, how much was sidewalls bending. Too much. :-( I can´t recommend this tires....:-( Pressure was normal, about 2,3-2,4 atm (for slalom is normal give even less!)
