Hello everyone I live in Buffalo NY area which we get depressing amount of snow which results in significant amount of salt as well. Wanted to see what people's thoughts on undercoating/rustproofing for our fists.
Personnaly I dont like to drill hole over the year those hole do rust even with the plug. You put the antirust trought the drain hole in the door and the fist rocker panel already have big Rubber plug underneath the car. If you really want à top notch job remove the door panel and remove the trunk side plastic panel so you can shoot antirust between the rear wheel panel and rear body.
Just a note, the rustproofing spray also protects the wiring connectors as well. I don't believe the person that did my car needed to drill any holes. If they did, it looks OEM...
