Thread Starter
#41
Went to Buttonwillow again on 28/1/17 with the Fiesta:
[video=youtube;EgEXRoyYA8A]http://www.youtube.com/watch?v=EgEXRoyYA8A[/video]
Good:
- New personal best with the ST at this track (2:08.29). Still a mostly stock car. The only performance enhancing stuff is the Quaife LSD and the camber bolts, everything else is heat management.
Bad:
- OEM brake system isn't suitable for track. Brake fade after 1 hot lap, decolorated calipers, disintegrated dust boots, scored (a brand new) front inside rotor. I won't track the car again until I get a BBK. I won't spend $2K on a Stoptech kit (at $1500 I'd think about it) and not a personal fan of Wilwood so currently looking at solutions from Brembo and AP Racing..
- Even with the Mishimoto oil cooler, and ambient temperatures below 60F, I managed to overheat coolant by running 3 laps in a row at a 2:09 pace. Coolant went over 250F during the 4th hot lap and car went briefly into limp mode. So, a bigger radiator is also a must-have mod before I take the ST to the track again.
- Quaife LSD is not that effective at Buttonwillow when it's dry. I can't hug the inside of T2 (Buttonhook) on 2nd gear, otherwise I get wheel spin on the inside front tire. Certainly not as bad as when I ran with the stock open diff. So I'm forced to take a wider line than RWD cars and use 3rd gear to ensure traction. I'd love to have a mechanical/clutch-type instead, but it's not a priority.
- The Pierce Motorsports Rear Traction Bar doesn't make a big impact at Buttonwillow. Did not run it on this particular day and didn't miss it. I love it in the canyons however (2nd & 3rd gear corners). But it also makes the ride on the street *very* harsh, so I probably will only be using for select backroads and maybe tracks like Streets of Willow. It's also possible my rear shocks are starting to go, so YMMV regarding ride comfort and/or handling improvements.
Good:
Bad:
