- Member ID
- #825
- Messages
- 165
- Likes
- 42
Hey guys,
I am now going to be machining both Delrin and solid aluminum steering rack bushings for the Fiesta and Fiesta ST! These have been a big hit for the Mk 1 and Mk 2 Focus, and pretty significantly increase steering control and response. It also forces the wheels to stay where you are pointing them, instead of being able to push against the rubber and twitch around turns, as well as immediately going where you point them, instead of loading against the rubber, and then finally unloading in that direction.
These work by replacing the squishy rubber bushings that the factory installs with Delrin, which is a very stiff and exremely durable acetal resin plastic. I finish it off with a steel center sleeve to prevent over compression.
I also make them from solid aluminum for the ultimate stiffness and durability, but you might experience extra harmonic vibration through the steering wheel.
Aluminum - $55 shipped
Delrin - $65 shipped
Please PM me if interested. Also, go check out my other sites!
Alexthemachinist.com
Facebook.com/alexthemachinist
Thanks,
Alex Gaebel
Monrovia, CA 91016
(626) 203-2058
[email protected]
INSTALLATION INSTRUCTIONS
http://www.fiestastforum.com/forum/threads/7232-Steering-Rack-and-Bushing-Install-Instructions
Thanks,
Alex Gaebel
Monrovia, CA 91016
(626) 203-2058
[email protected]
