- Member ID
- #2134
- Messages
- 4,097
- Likes
- 948
Just saw this. Really tempting... Just dont want to be the first.
Another in the line of CANopener products! This simple to install kit allows you to add a backup camera to any Ford or Lincoln vehicle with SYNC 2 (MyFord / MyLincoln Touch) or SYNC 3 in three easy steps:
Install our (optional) Plug n' Play "T" harness behind the touchscreen
Plug the camera of your choice into our T harness
Easily enable the backup camera input using included CANopener? Flash programmer
The CANopener? Flash programmer plugs into your vehicle's OBDII diagnostic port under your steering column. In a matter of seconds, the Flash will enable the backup camera feature on your vehicle's touchscreen. It will show the attached backup camera when the vehicle is placed in reverse - just like it would from the factory!
INCLUDED:
CANopener? Flash Programmer
Camera Video "T" Harness
Detailed Printed Instructions
FEATURES:
Easy Plug n' Play install
Simple DIY vehicle programming
CAMERA SUPPORT
Our harness will support any vehicle backup camera with a standard RCA connection. Please note, you will need to follow the camera instructions for sourcing power.
COMPATIBILITY:
2011-Current Ford & Lincoln vehicles w/ SYNC 2 (MyFord / MyLincoln Touch or SYNC 3 (8" Touchscreen) If you have the "Jukebox" feature, then this is NOT for you. Not sure? Ask us FIRST!
https://www.4dtech.com/ford-camera-programmer-for-sync-2-3-8-screen/
INCLUDED:
FEATURES:
CAMERA SUPPORT
COMPATIBILITY:
