charge pipe question
Clinton
Hello. I have a MAP intercooler. I was wondering, what charge pipes would work with it besides the MAP ones? Ive heard that the hot charge pipe was the only one that really should get swapped. I dont mind buying the cold side either but was just curious if it was my only option.
Whittier
Check out depo their stuff is pretty affordable. In theory all hard pipes should match right up
V
Clinton
Thanks for the replies. I will definitely look into them. Will the cold charge pope help with an upgraded turbo lole the c39 or x-47?
Some on here have gone even to a BIG turbo/BIG power, and have not changed out the cold side pipe, and claimed/proven that it did not hurt them one iota.
But, if/when I go even to a hybrid, I will probably change out the cold side pipe (I plan to do the hot side when I install my cp-e IC, with a cp-e hot side pipe, and Mountune/Samco hoses, and TurboSmart Constant tension clamps). ;)
V
Clinton
Anyone with experience with the MAP charge pipes with the BOV? I was thinking maybe i would like to keep it all MAP out. Maybe
