For those that don't like the holes when using a wing riser kit a 2 1/4 npt plug is just about the right size. Soft enough to easily cut and drill a hole to pass the wire. Now if you have not cut your wire to install a 3rd light flasher you will need a bigger hole or cut a slot to push the wire in. Also put the hole to one side as the tube and wires are not dead center. To be honest this is not required as the holes are there before the riser anyway and I had plenty of dust in the wing. If you do this make sure to have long needle nose to drag (carefully) the wire and hose while you push.
