What was your first Fiesta ST mod?
  • Intake
    Votes: 63 11.5%
  • Exhaust
    Votes: 53 9.7%
  • Tune
    Votes: 91 16.6%
  • Other Performance (Please List)
    Votes: 42 7.7%
  • Suspension (Coilovers/Springs/Shocks)
    Votes: 16 2.9%
  • Tires & Wheels
    Votes: 37 6.7%
  • Exterior Aesthetics
    Votes: 52 9.5%
  • Lighting
    Votes: 18 3.3%
  • Stereo & Speakers
    Votes: 6 1.1%
  • Window Tint
    Votes: 113 20.6%
  • Other (Please List)
    Votes: 58 10.6%
  • Total voters
    549
Not that this is a biggie in most ways, but the very first thing I did was remove the dealer badge from the rear end. They didn't ask to place it, and I'm generally not inclined to giving free advertising. Maybe just my thing, but . . . .
Exactly. Took that crap off the day after I brought her home.
Jumped right to stage 3 cobb right out of the gate. Well, 1-3 in quick succession. Just have to muster the energy to finish the downpipe.
Did stage 1 and then a week later did stage 2 qnd then a month later stage 3. A month later i did a pro tune. 3 weeks later did wheels and tires. In between those times i did a dozen other small mods. Bumper is cut up and im in the process of sanding it down.
. A couple weeks i get my flex fuel kit installed.
rexdriver85
That front bumper looks awesome with the COBB IC peeking through. Great job. [emoji108]
Thank you. Im cutting those vertical supports out and make it look really clean. Oh and i totally forgot the best mod of them all the turbosmart dualport shorty blow off valve. Fixed my purging i was getting while building boost.
Kip2MyLou
What purging? And did you feel a big difference between your stage 3 and your pro tune?
And I was planning on cutting my bars too. Difficult job?
As i would accelerate the bpv would open early instead of holding boost until i released the throttle. The factory spring is weak and i highly recomend this valve. I have a video of it as well. Not that big of gains between cobbs stage 3 ots and pro tune. I gained maybe 4 hp and 18wtq. I used a dremmel to cut it and now im sanding it down.
Also it depends on how you want to be tuned. Im all for low end torque and less top end.
Kip2MyLou
Oh okay. And good info. I'm going to hopefully get a tune from Randy so just wondering what the differences were. And it looks good man.
18wtq should be noticeable
dyn085
The spring doesn't hold full boost, only about 5.5 psi.
SPhilli911
My first mod was nothing crazy, FSWerks short shift kit. Easy install. Put it in only a week after owning the car, so it's honestly hard to tell the difference from stock shift throws.
I have boombas short kit with their sets of bushings and it gives it more of a mechanical feel. Pretty much the only thing you should buy from them as everything else is useless.
SPhilli911
I might end up getting that as well. The FSWERKS "kit" was just the transmission adapter that shortened the throw (25%) only, no shift lever at all.
My first mod was yellow fog light film. My first performance mod was a RMM.
Yeah i didnt end up purchasing the shift lever for the 25 percent throws is short enough for me. I want some travel between gears just to enjoy the driving. Those bushings do help. Feels more solid with gear engagement.
