It's about Time....Modern GDI OIL for Turbos
A7xogg
Sweet! More companies going to this before gf-6 is mandatory= less of a price hike
None of these next generation oils are made with bargain basement components. The engineering challenges to get a fluid to perform and last under the conditions they endure is a very heavy task. Long drain intervals, sludge resistance, low volatility, resistance to cavitation, stable viscosity under a wide range of conditions. Corrosion protection and reliable dispersion along with a host of other requirements. Compared to the very best oils of the last twenty years, this stuff is like a liquid version of superman. It won't be in the same league.
Thread Starter #24
According to this short post by a company named Lube Tech, the first licenses for gf-6 labelling will be effective September 1, 2018. I wonder if the new Valvoline oil meets the standard but just cannot be labeled gf-6 until then?
http://lubetechblog.com/understanding-gf-6-oil-specs/
I deal with this company on a weekly basis here in Mn....it will be interesting how this all unfolds with who will be the first.
Yes, I forgot about that 'split spec' feature, and YES it is going to be an EXTREME base stock/additive challenge to get the proposed GF-6B 'fuel saving' 0W-5/7 and 0W-10 weight oils to meet those specs and not be excessively volatile, and carbon deposit forming in DI engine scenarios (besides all of the oil film boundary challenges!).
The GF-6A will be the one which meets/exceeds the various Dexos/Honda/etc. LSPI reducing needs/specs for the 0/5W-20/30/etc. viscosities, correct?
Yes. That's how i understood it to be. Spec 6A is the new improved spec in general, replacing gf5. Spec 6B is the new tech low viscosity/SFE stuff.
It's usually a good idea to stand back and wait at least a year; let others be the guinea pigs. There are often unintended consequences that laboratory testing misses, dismisses or diminishes.
I asked that precise question to the Ravenol tech this morning about their own mostly PAO base stock, DXG 5W-30, and he basically said yes, they FULLY expect this currently available oil to exceed those GF-6A specs once they are in effect, with only a label change to make it official.
Yes, I have serious doubts that even most GTL and Visom group 3+ base stocks, let alone plain old super hydrocracked group 3 base stocks will 'cut it' to allow these super low weight oils to meet these new standards.
A7xogg
Hmm, what about 5w20?
A7xogg
5w20 will be a GF-6A. It will be interesting to see what happens with 10W30 and 10W40. I really don't see any cost or functional benefits to doing any major rework on these specs. They are unsuitable for any modern GDI engines. The heavier multi-viscosity oils are rapidly falling in demand.
They (Ravenol) do make a good 5W-20, which I believe meets/beats our 945-A spec, but it is NOT one of their oils which is specifically aimed at reducing LSPI events.
They do also have a 0W-20 which is a LSPI reducing formulated oil, which I would consider using for the winter OCI in the future. ;)
#33
Yes, I suspect that the heavier weight oils will just continue on as SM/SN and GF-5 (at 'best') spec for older port injected use, and/or even carbed ancient ride use.
(Are the latest Coyote engines still port injected only? IF not, then maybe the various 5W-50s out there will also be formulated for DI use as well? [dunno])
#34
Gen 3 Coyote is GDI. I liked the gen2/Boss302 version a whole bunch. One or the other of those will be my next purchase.
A7xogg
#35
Where did you see that? I can't find anything about which oils are lspi reduction and which arent
#36
Think we are all missing a very import fact. Oil does not touch the back of the valves, so how is it going to help deposit reduction.
#37
Oil gets into the combustion chamber either as vapor/mist from the PCV system through the intake system, or measured amounts past the piston's ring pack, by design, in order to lubricate/protect the cylinder walls, or in the case of worn/faulty valve stem seals (both intake AND exhaust) onto the valve stems and therefore onto the backs of the valves.
THIS is why both a low volatility oil, and an oil with a detergent additive pack which does NOT promote deposits when burned in the chamber are paramount to keeping the intake valves functionally 'clean' in a DI engine.
It is the combustion by products from the even minute amounts of oil being burned in even a fully properly functioning modern engine which contributes to the causes of deposits.
It is NOT that any specific detergents/solvents in any of these oils are 'scrubbing' the backs of the valves (it is a PREVENTION measure these oils seek, NOT a 'fix' or remedial solution to an already existing deposit condition). ;)
#38
Please utilize the search feature. Oil mist is present in the intake and pcv systems. It has been the subject of conversation on an almost Biblical scale.
Thread Starter #39
I'm going to apologize to everyone right now....I never thought this would get that technical and turn into BITOG. Just thought we would get some people to try it....I know I will.
#40
Hey, some parts of BITOG are useful and very informative, just NOT their how shall I put this, extremist ONE-SIDED, "General And Off Topic" forum. [poke] LOL
