- Member ID
- #1846
- Messages
- 562
- Likes
- 458
I picked up a set of DEPO Euro Headlamps about 2 months ago. My first set of H7 low beam bulbs were Phillips Diamond Vision and I was very unimpressed with the output so I decided to take a chance and go with a good set of LEDs. I chose the PIAA Platinum LED H7 bulbs.
I ordered a set of 75mm rubber headlight housing caps from The Retrofit Source since I expected the bulbs would likely extend out past the housing a bit.
I neglected to take pics when I installed them into the headlight but install is straight forward. I found it was easier to remove the heatsink from the bulb before installing it into the headlight then reinstall it after the bulb was clipped in. After the heatsink was installed back onto the bulb I connected the driver and tucked it inside the headlight assembly. The 75mm extended cap fit perfectly on the headlight housing and left plenty of space for the bulb and heatsink.
Here's a daytime pic
And here's the cutoff
I've been running these bulbs for a few weeks now and I'm very impressed with them. I was planning to retrofit in the future but now I'm having second thoughts about needing to.
